Importing XYZ Data into MDT5
Does anyone know the best method to import XYZ Coordinate data into MDT5?
I have an Excel Spreadsheet with point data for an impellor. I wish to create a spline through these points.
RE: Importing XYZ Data into MDT5
Dear Fortyplus,
The following VBA code reads data from EXCEL and draws an spline in autocad.
You should keep open the excel document containing the data while running the macro. All data must start from address A1 in excel active sheet and X, Y, and Z coordinates for each fitpoint is read respectively from columns A, B, and C.
Copy and paste the following code into a module in AutoCAD VBA editor and save it under an arbitrary name. Then run the "Main" macro using the  "VBARUN" command.
Option Explicit
Option Base 0
Sub Main()
    Dim ex As Object
    Dim tt As Worksheet
    Dim I As Integer
    Dim J As Integer
    Set ex = GetObject(, "EXCEL.Application")
    Set tt = ex.ActiveSheet
    I = 0
    tt.Cells(1, 1).Activate
    Do While Not IsEmpty(ex.ActiveCell.Offset(I, 0))
        I = I + 1
    Loop
    I = I * 3 - 1
    Dim FitPoints() As Double
    ReDim FitPoints(I)
    I = (I - 1) / 3
    J = 0
    Do While J <= I
        FitPoints(0 + J * 3) = ex.ActiveCell.Offset(J, 0)
        FitPoints(1 + J * 3) = ex.ActiveCell.Offset(J, 1)
        FitPoints(2 + J * 3) = ex.ActiveCell.Offset(J, 2)
        J = J + 1
    Loop
    Dim startTan(2) As Double
    Dim endTan(2) As Double
    Dim SPLObj As AcadSpline
    startTan(0) = 1: startTan(1) = 0: startTan(2) = 0
    endTan(0) = 0: endTan(1) = -1: endTan(2) = 0
    Set SPLObj = ThisDrawing.ModelSpace.AddSpline(FitPoints, startTan, endTan)
    ZoomAll
End Sub
Farzad
