Anaerobic sludge mixture
We have 8 diameter tank to hold primary sludge. We are looking for sludge mixture to produce volatile fatty acid (VFAs) under anaerobic condition. Any suggestion on vertical mounted Vs submerged mixture. We had submerged mixture but it accumulate the sludge on the walls and not producing good mix.
Thank for you time and input.
RE: Anaerobic sludge mixture
A top mounted mixer will generally provide better results.
What does "accumulate sludge on the walls" mean?
The general wisdom is that for good, efficient mixing you want a large mixer. For 8m dfiameter a top mounted mixer seems to be the way to go.
