3/4" A325 N bolt-nut penetration
Should any structural bolt have a complete penetration of the nut or is there some leeway to allow not to? I am looking at some structural connections where the bolt doesn't penetrate the nut entirely.
Can a partial capacity be assumed from partial penetration?
RE: 3/4" A325 N bolt-nut penetration
similar to that link. That one is for anchor bolts but the theory is the same.
The typical question that triggers the discussion comes from someone who has a bolt or stud whose end is flush with the nut, and whoever bought the bolts or embedded the studs in concrete doesn't want to buy and install longer ones.
If your bolt is not getting at least flush with the far side of the nut, you don't _have_ a _structural_ connection.
For your particular unspecified situation, somewhere in the world, you can assume anything you like, but the risk is yours. Did you bet your house already?
Mike Halloran
Pembroke Pines, FL, USA
In complete agreement with Mike Halloran on this one, I've always advocated the bolt should have at least 1.5 threads past the end of the nut.
If you consider the failure modes for a nut and bolt, its preferable for the bolt to fail as opposed to the threads of the nut stripping which is normally guaranteed provide the whole of the nut is engaged on the bolt.
Now if the bolt is only partially engaged can you be sure the nut won't strip? My advice change is to change the bolts for longer ones.
Totally off this topic, but saw your post a few years ago regarding T shaped structural clay tile. I ran into the same thing and did some research on it and found an ad in Sweets Catalog from 1920 that lists Denison Interlocking Tile and it's load bearing capacities:
https://books.google.com/books?id=K9c7AQAAMAAJ&...
Sorry to hijack this thread but thought you might want to see it.
