Flexural Concrete Paving
We are having areas in our paving that is cracking around bollard and manhole blockouts. The engineer did not indicate any reinforcing for the flexural 650 psi concrete in the paving. The owner is now asking that we remove all panels that have full depth cracking. The contractor doesn't feel obligated to replace the panels since their was no reference in the specifications that require it. The specifications only reference ACI 301 and no where in ACI 301 states you must replace the concrete panels. The owner has also stated he doesn't think you can use epoxy in unreinforced concrete. Does anyone have any input on my situation?
RE: Flexural Concrete Paving
As for epoxy repair, that can be done. It makes no difference if the concrete is reinforced or not...epoxy will still work.
A sketch of the cracking patterns (and penetrations) would be helpful for our continued input.
