NX 9 Rotating Dimension & Appended Text
I am trying to add some text to a dimension that I rotated by 90 degrees. I know I was able to do this in previous versions of UG NX, but now whenever I try to add some appended text, it automatically rotates the dimension back to its default location. I can not find any way to modify the rotational angle with appended text added to it. Is this a bug, or am I missing something? I have tried it with Perpendicular-Linear, Inferred-Linear and Horizontal-Linear. None of them seem to make a difference.
You can see what I'm talking about below.
It doesn't matter what I try and change the angle to after I add the text, it doesn't change the actual angle, and as soon as I exit the settings box, it reverts back to 0. Is there any way I can keep this from happening?
RE: NX 9 Rotating Dimension & Appended Text
Are you willing to upload a part that has the issue in it?
Anthony Galante
Senior Support Engineer
NX3 to NX10 with almost every MR (21versions)
Oh, and since I didn't think of it before, the version of NX 9 that I'm using is NX 9.0.2.5.
I'm using NX 9.0.3.4; you might try installing that MR, perhaps the issue you describe is limited to 9.0.2.5.
www.nxjournaling.com
You could contact GTAC to see if the same (or similar) bugs were reported. I think they maintain a list of what was fixed in each maintenance release; boring reading to be sure, but it might give you a definitive answer.
