show / hide in multiview mode
In multi view mode, is it possible to hide a particular component in left window and show the same in right window. By this way, I can keep the whole assembly in left and any other single part only in right window. Kindly suggest.
Suresh
Suresh
RE: show / hide in multiview mode
if you have a second window of your assembly, then the instance will also be hidden.
