Catia V5 Parametric to dumb solid assembly conversion
In Catia-V5, if you want to convert Parametric Assembly to Dumb (Dead) solid assembly... then ...
- Use assembly "Symmetry" command & create symmetrical assembly
- Then again use assembly "Symmetry" command .... This will generate assembly with Solids link.
- Save complete assembly with all newly created assembly for symmetry & again for re-symmetry
- Close session & delete original files... that is files other that file names starting with "Symmetry of Symmetry of"
- With that you will get assembly with all dumb solids .... You will have to rename the files structure to omit "Symmetry of Symmetry of" from file name.
Vikas
Vikas
RE: Catia V5 Parametric to dumb solid assembly conversion
