NX8.5.3.3 Dimension error - Object does not have the required csys matrix
Problem occurs trying to add an angular dimension in drafting
Horizontal dimension has been added using a tangent point and end point
Have tried to create angular dimension using horizontal dimension as one object and angle edge as second object
Error message is raised and dimension is not created
Is there a work-a-round or fix for this problem ?
RE: NX8.5.3.3 Dimension error - Object does not have the required csys matrix
Hello Guys,
I am getting same error as mentioned above for drawing file.
When I clicked on any dimension placed in drafting file, It shows me error "Given Object Does not have required csys matrix".
After showing error, it automatically comes out of drafting module, Is there any solution to this?
Attached is the error message displayed.
It's fixed in a 9.0.3 MP ... in early NX9 releases, the files wouldn't even open.
make use of the Vector option in the meantime.
NX 9.0.3.4
NX 10.0.1.4 (Testing)
Windows 7 64 (Windows 8.1 Tablet)
Philipd,
Could you Pl elaborate more about vector option?
You can't use the extension line of the horizontal/vertical dimension when creating the angular dimension.
Change the "Selection Mode" to "Vectors and Objects" and define a vector.
NX 9.0.3.4
Hi Philipd,
Yes, thats true. I have taken care while dimensioning to select the proper edges and objects.
Is there anything else which can create a similar error of csys matrix?
Hi ckadam,
take a look in GTAC for FAQ 001-1967815
