Plate bends when auto blasted
Dear Professional,
I would like to understand why a 2mm thickness carbon steel plate bends when it is auto blasted (Mixture of Steel grit and Steel Shots). Has anyone encountered this issue.
Thank you.
Thank you.
RE: Plate bends when auto blasted
People also use thin strips in a blast machine to measure the intensity of the blasting based on how much they bow.
Impact matters. Energy matters.
