Defining a part for the Reuse Library
Hello everyone!
How do I define a piece part for the Reuse Library? I have found only one way so far - to simply copy a part into the library folder. In later version of NX we have a 'Part' option as a reusable object type, bit it does not create an actual part - or at least I did not find a way to do that.
Any advice?
www.cadroad.com
RE: Defining a part for the Reuse Library
The Command "define Re-usable oject" should cover that....
In here you have different options, one of which is a part.
Ronald van den Broek
Application Specialist
Winterthur Gas & Diesel Ltd
NX8.5.3 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP EliteBook 8570W Intel(R) Core(TM) I7-3740QM CPU @ 2.70GHz, 16Gb Win7 64B
Did you read original question? 'Part' option does not seem to creating a part, it creates reusable feature instead.
www.cadroad.com
If what you want is the entire part, then placing a copy of the part in the library folder works fine. Now if you want to do something fancy with parameters and such when you add that part to your model, that requires a bit more effort.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Is the name of the entry in the library always a .prt filename, or can we use some attribute to override the filename and be displayed instead of it?
www.cadroad.com
