NX9, View > Operation > Regenerate, Work no longer works as it previously did in earlier versi
I was encouraged by this thread, http://www.eng-tips.com/viewthread.cfm?qid=355866 and John Bakers initial response. Nobody took the bait, and his final response didn't disclose exactly how to solve this issue in NX9.
Anyone?
RE: NX9, View > Operation > Regenerate, Work no longer works as it previously did in earlier versi
There is a white paper in the GTAC solution center that may help you.
www.nxjournaling.com
I don't understand what it is that you want, you run NX9 and when you zoom in , the facets are a bit crude, - too crude.
Have you tried what I proposed in the thread you link to ?
= RMB the graphics window - Update display.
I see no difference in what that does to earlier versions.
It will give you updated facets, - a smooth look.
- What bait , from who, in what thread ?
Tomas
