minimum thickness of members thant can welding
Could anyone suggest what is the minimum thickness of pipes that can welded in case of light structure?
RE: minimum thickness of members thant can welding
The following limits can be used as safe minimum thicknesses that can be welded  by various welding processes:
Gas Metal Arc Welding (also called Metal Inert Gas Welding): 1.5 mm, but can be as low as 0.5 mm with tighter control of welding current.
Gas Tungsten Arc Welding (also called Tungsten Inert Gas Welding): 0.12 mm.
Plasma Arc Welding: 0.075 mm, but can be as low as 0.025 mm.
Electron Beam Welding: foil
Laser Beam Welding: < 0.12 mm
