Broken views with 2D compare in Teamcenter
My company produces lots of long, slender parts (motor driveshafts) so we use a lot of broken views in our drafting. I noticed after starting work here that broken views in NX shift the view location on the field of drawing very slightly when they update. This, in turn, dramatically reduces the effectiveness of the 2D compare feature in Teamcenter when you're trying to check a revision to the drawing. Even though most of your dimensions may be the same, everything is highlighted red and green because the broken views and/or associated dimensions shifted a bit.
Does anyone have a solution or workaround to this issue?
NX version 8.5.3.3
Teamcenter 9.1.2.3
Windows 7
NX version 8.5.3.3
Teamcenter 9.1.2.3
Windows 7
RE: Broken views with 2D compare in Teamcenter
