NX10 extrude?
NX10 extrude?
NX10 extrude?
Hi
I have recently changed from NX8 to NX10.
What happened to the extrude function's offset options. I cannot seem to find that. That is single or double sided offsets so that you can extrude a tube from a single circle?
Attie
RE: NX10 extrude?
Have you tried resetting your extrude menu?
Ronald van den Broek
Application Specialist
Winterthur Gas & Diesel Ltd
NX8.5.3 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP EliteBook 8570W Intel(R) Core(TM) I7-3740QM CPU @ 2.70GHz, 16Gb Win7 64B
RE: NX10 extrude?
Hallo Ronald
How do I do that? I just look in the extrude function window and cannot find the tabs for offset.
Attie
RE: NX10 extrude?
Click the little black arrow just above the OK-APPY-CANCEL buttons
edit to add:
also, you can click the "settings" icon looks like a Gear, next to the name and select more
RE: NX10 extrude?
It's definitely there ... try choosing the RESET option at the top of the dialog
NX 9.0.3.4
NX 10 (Testing)
Windows 7 64 (Windows 8.1 Tablet)
RE: NX10 extrude?
Thanks Guys
Got it. Click on the round gear thing and get dialog options, then >>Extrude(more)
Thanks a lot
Attie
