Airflow Pattern
Airflow Pattern
Hi, Everyone
Is there a textbook or a website that I can study about the behavior or airflow pattern?
The idea is simple: using a blower/fan on one end of a pipe with a deflector (blade/propeller) in the middle and creating whirl airflow pattern. In other word, pressurized air is forced into a pipe with a deflector to change the flow pattern.
I am no aerodynamic engineer, but I believe it relates to air pressure, air flow rate, reynold's number, pressure losses, etc.
If there is any guideline or textbook regard to this, please don't hesitate to with the reply below.
Thanks in advance
Thanks in advance
RE: Airflow Pattern
Wind tunnels acually have a problem with this and put 'grids' of vanes to try and straighten the airflow - plus contra rotating fans on occasion.
Jet engine compressors on the other hand often have vanes to help guide air flow.
So depending exactly what you're trying to do take a look at one or other of those maybe.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
RE: Airflow Pattern
The application that I am working on is to use the advantage of air pattern to create or furnish better combustion for heating. The setup is really similar to jet engine compressors with vanes.
something like this
http://cr4.globalspec.com/PostImages/200804/retent...
(source:google image)
The whirling air pattern will help to the process of combustion or concentrate the flame. So, what I am trying to find is that under what kind of condition (air pressure or air flow rate from a blower) with air delfector (such as van) can create the whirling airflow pattern.
Is there a design guide of designing the jet engine compressor vane? Maybe I can start with that.
Does a blower (i.e. leaf blower) create rotation of the air mass going through the tube as well?
RE: Airflow Pattern
An axial fan on the other hand should tend to create a moving mass of air with an overal rotation.
Try googling terms like "axial fan airflow rotation" or similar.
