Title Capitalization with Adjective Phrases
I'm writing a title that contains the phrase "drop-in" as in, "Drop-In Replacement". Do I write the "in" in lowercase (Drop-in) because "in" is a preposition, or capitalize it because I'm using it as a part of "Drop-In", which is not a prepositional phrase?
RE: Title Capitalization with Adjective Phrases
Do you have a style guide? If so, follow it. If not, how do likely suppliers write it?
I think you could use either, but when you pick one be consistent. Personally I'd go with Drop-In, but that's just me.
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
It's a Friday, and we had a two-beer (Two-Beer?) lunch, so anything I say may not be used against me, or as a very good guideline (guide-line?) Guide-Line...
Here's a guide for often-hyphenated words, and non-too-common uses and often-wrongly-used uss of hyphenization...
[link http://www.grammarmudge.cityslide.com/articles/art...]http:
(They were two "talls")
David
Connect with me on LinkedIn. http://lnkd.in/fY7-QK
We are both Technical Writers.
And, the various style guides are all over the map.
So, it really does boil down to house and industry preferences.
You can then pick a style guide that agrees with you.
cheers
jay
Jay Maechtlen
http://www.laserpubs.com/techcomm
