Concrete I beam
Concrete I beam
Hi everyone,
Could someone help me with this problem:
Consider 2 concrete sections; First one is an I beam as a unit cross section, and the other one is an I section again but this time with 2 parts in which the bottom part of the section is not connected to the upper part (so in this case we have a T beam and the bottom part). How can you explain the structural behavior of these two different sections when they act as beams?
Many thanks
Many thanks
RE: Concrete I beam
RE: Concrete I beam
Could you tell me how shear flow affects the behavior of the separate beams?
RE: Concrete I beam
RE: Concrete I beam
RE: Concrete I beam
RE: Concrete I beam
Anyway, I need much more evidential details about this problem. Could you guys recommend me some pages of a book on this special subject?
This is not a homework, it's just a question appeared in my mind.
RE: Concrete I beam
RE: Concrete I beam
