Need Help on below journal
I have created a journal to update some of the fonts in Dwg, In the below code I am unable to get update from Table fonts and also I need some inputs for the lettering size factor in view label style...I want to control it through VBA...
Thanks in Advance....
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports System.Windows.Forms
Imports NXOpen.Annotations
Imports NXOpen.Utilities
' NX Font Update
' Journal created by Alto on 20-05-2015
Module NXJournal
Dim ufs As UFSession = UFSession.GetUFSession()
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
Sub Main()
'Update Note Dimension
For Each note1 As Annotations.Note In workPart.Notes
Dim lineAndArrowPreferences1 As Annotations.LineAndArrowPreferences
lineAndArrowPreferences1 = note1.GetLineAndArrowPreferences()
Dim letteringPreferences1 As Annotations.LetteringPreferences
letteringPreferences1 = note1.GetLetteringPreferences()
Dim fontIndex1 As Integer
fontIndex1 = workPart.Fonts.AddFont("ideas_iso")
' Font is associated with integer 4
Dim generalText1 As Annotations.Lettering
generalText1.Size = 0.1
generalText1.CharacterSpaceFactor = 1.0
generalText1.AspectRatio = 1.0
generalText1.LineSpaceFactor = 1.0
generalText1.Cfw.Color = 6
generalText1.Cfw.Font = 51
generalText1.Cfw.Width = Annotations.LineWidth.Thin
letteringPreferences1.SetGeneralText(generalText1)
note1.SetLetteringPreferences(letteringPreferences1)
note1.RedisplayObject()
Next
'Update Special Notes of BE
For Each note2 As Annotations.Note In workPart.Notes
Dim Text1(0) As String
Text1 = note2.GetText
If Text1(0) = "<W@DB_PART_MARK>" Then
Dim lineAndArrowPreferences2 As Annotations.LineAndArrowPreferences
lineAndArrowPreferences2 = note2.GetLineAndArrowPreferences()
Dim letteringPreferences2 As Annotations.LetteringPreferences
letteringPreferences2 = note2.GetLetteringPreferences()
Dim generalText2 As Annotations.Lettering
generalText2.Size = 0.06
generalText2.CharacterSpaceFactor = 1.0
generalText2.AspectRatio = 1.0
generalText2.LineSpaceFactor = 1.0
generalText2.Cfw.Color = 2
generalText2.Cfw.Font = 51
generalText2.Cfw.Width = Annotations.LineWidth.Thin
letteringPreferences2.SetGeneralText(generalText2)
note2.SetLetteringPreferences(letteringPreferences2)
note2.RedisplayObject()
ElseIf Text1(0) = "<W@DB_JOB_NUMBER>" Or Text1(0) = "<W@$SH_SHEET_NUMBER> <W@$SH_NUMBER_OF_SHEETS>" Then
Dim lineAndArrowPreferences3 As Annotations.LineAndArrowPreferences
lineAndArrowPreferences3 = note2.GetLineAndArrowPreferences()
Dim letteringPreferences3 As Annotations.LetteringPreferences
letteringPreferences3 = note2.GetLetteringPreferences()
Dim generalText3 As Annotations.Lettering
generalText3.Size = 0.09
generalText3.CharacterSpaceFactor = 1.0
generalText3.AspectRatio = 1.0
generalText3.LineSpaceFactor = 1.0
generalText3.Cfw.Color = 2
generalText3.Cfw.Font = 51
generalText3.Cfw.Width = Annotations.LineWidth.Thin
letteringPreferences3.SetGeneralText(generalText3)
note2.SetLetteringPreferences(letteringPreferences3)
ElseIf Text1(0) = "<W@DB_PART_NAME>" Then
Dim lineAndArrowPreferences4 As Annotations.LineAndArrowPreferences
lineAndArrowPreferences4 = note2.GetLineAndArrowPreferences()
Dim letteringPreferences4 As Annotations.LetteringPreferences
letteringPreferences4 = note2.GetLetteringPreferences()
generalText3.Size = 0.125
letteringPreferences4.SetGeneralText(generalText3)
note2.SetLetteringPreferences(letteringPreferences4)
End If
Next
'Update Dimension and appended text
Dim Dimension1 As Dimension
For Each Dimension1 In workPart.Dimensions
Dim dimensionPreferences1 As Annotations.DimensionPreferences
dimensionPreferences1 = Dimension1.GetDimensionPreferences()
Dim letteringPreferences5 As Annotations.LetteringPreferences
letteringPreferences5 = Dimension1.GetLetteringPreferences()
' Font is associated with integer 3
Dim dimensionText1 As Annotations.Lettering
dimensionText1.Size = 0.1
dimensionText1.CharacterSpaceFactor = 2.0
dimensionText1.AspectRatio = 1.0
dimensionText1.LineSpaceFactor = 1.0
dimensionText1.Cfw.Color = 6
dimensionText1.Cfw.Font = 51
dimensionText1.Cfw.Width = Annotations.LineWidth.Thin
letteringPreferences5.SetDimensionText(dimensionText1)
letteringPreferences5.SetAppendedText(dimensionText1)
letteringPreferences5.SetToleranceText(dimensionText1)
Dimension1.SetLetteringPreferences(letteringPreferences5)
lineAndArrowPreferences1 = Dimension1.GetLineAndArrowPreferences()
dimensionPreferences1.Dispose()
letteringPreferences5.Dispose()
Dimension1.RedisplayObject()
Next
'Update all Id symbols Line and Arrow preferences not included as User need different Arrowheads
For Each Idsymbol1 As Annotations.IdSymbol In workPart.Annotations.IdSymbols
Dim symbolPreferences1 As Annotations.SymbolPreferences
symbolPreferences1 = Idsymbol1.GetSymbolPreferences()
lineAndArrowPreferences1 = Idsymbol1.GetLineAndArrowPreferences()
Dim letteringPreferences6 As Annotations.LetteringPreferences
letteringPreferences6 = Idsymbol1.GetLetteringPreferences()
Dim generalText4 As Annotations.Lettering
generalText4.Size = 0.1
generalText4.CharacterSpaceFactor = 1.0
generalText4.AspectRatio = 1.0
generalText4.LineSpaceFactor = 1.0
generalText4.Cfw.Color = 6
generalText4.Cfw.Font = 51
generalText4.Cfw.Width = Annotations.LineWidth.Thin
letteringPreferences6.SetGeneralText(generalText4)
Idsymbol1.SetLetteringPreferences(letteringPreferences6)
symbolPreferences1.IdSymbolSize = 0.35
Idsymbol1.SetSymbolPreferences(symbolPreferences1)
letteringPreferences6.Dispose()
lineAndArrowPreferences1.Dispose()
symbolPreferences1.Dispose()
Idsymbol1.RedisplayObject()
Next
'Update Label Font for all the Labels not letter size factor
Dim NULL_TAG As NXOpen.Tag = NXOpen.Tag.Null
Dim obj As NXOpen.Tag = NULL_TAG
Do
obj = ask_next_drf_entity(obj)
If obj = NULL_TAG Then
GoTo end1
End If
' Check whether returned Tag is UF_draft_label_subtype
Dim type As Integer = Nothing
Dim subtype As Integer = Nothing
ufs.Obj.AskTypeAndSubtype(obj, type, subtype)
Dim nxobj As NXObject = NXObjectManager.Get(obj)
If nxobj.GetType().ToString() <> "NXOpen.Annotations.Label" Then
Continue Do
Else
Dim Label1 As Annotations.Label = nxobj
Dim letteringPreferences7 As Annotations.LetteringPreferences
letteringPreferences7 = Label1.GetLetteringPreferences()
Dim generalText5 As Annotations.Lettering
generalText5.Size = 0.1
generalText5.CharacterSpaceFactor = 1.0
generalText5.AspectRatio = 1.0
generalText5.LineSpaceFactor = 1.0
generalText5.Cfw.Color = 6
generalText5.Cfw.Font = 51
generalText5.Cfw.Width = Annotations.LineWidth.Thin
letteringPreferences7.SetGeneralText(generalText5)
Label1.SetLetteringPreferences(letteringPreferences7)
letteringPreferences7.Dispose()
Label1.RedisplayObject()
End If
Loop Until obj = NULL_TAG
End1:
Dim NULL_TAG1 As NXOpen.Tag = NXOpen.Tag.Null
Dim obj1 As NXOpen.Tag = NULL_TAG1
Do
obj1 = Ask_Tab_note(obj1)
If obj1 = NULL_TAG1 Then
GoTo end2
End If
ufs.Obj.AskTypeAndSubtype(obj1, type, subtype)
Dim nxobj1 As NXObject = NXObjectManager.Get(obj1)
If obj1.GetType().ToString() <> "Tabular Note Cell" Then
Continue Do
Else
Dim Cell1 As Annotations.Note = nxobj1
Dim letteringPreferences8 As Annotations.LetteringPreferences
letteringPreferences8 = Cell1.GetLetteringPreferences()
Dim generalText6 As Annotations.Lettering
generalText6.Size = 0.3
generalText6.CharacterSpaceFactor = 1.0
generalText6.AspectRatio = 1.0
generalText6.LineSpaceFactor = 1.0
generalText6.Cfw.Color = 6
generalText6.Cfw.Font = 51
generalText6.Cfw.Width = Annotations.LineWidth.Thin
letteringPreferences8.SetGeneralText(generalText6)
Cell1.SetLetteringPreferences(letteringPreferences8)
letteringPreferences8.Dispose()
'Dim cellPrefs1 As UFTabnot.CellPrefs
'cellPrefs1 = Cell1.getcellPrefs
'cellPrefs1.format = UFTabnot.Format.FormatText
'cellPrefs1.text_font = 51
'cellPrefs1.text_height = 0.06
'cellPrefs1.text_aspect_ratio = 1.0 '
'cellPrefs1.text_angle = 0.0
'cellPrefs1.text_slant = 0.0
'cellPrefs1.line_space_factor = 1.0
'cellPrefs1.char_space_factor = 1.0
'cellPrefs1.text_color = 6
'cellPrefs1.text_density = "Thin"
'cellPrefs1 = Cell1.SetcellPrefs
Cell1.RedisplayObject()
End If
Loop Until obj1 = NULL_TAG1
End2:
End Sub
Public Function Ask_Tab_note(ByRef obj1 As NXOpen.Tag) As NXOpen.Tag
Dim part As NXOpen.Tag = workPart.Tag
ufs.Obj.CycleObjsInPart(part, UFConstants.UF_tabular_note_cell_subtype, obj1)
Return obj1
End Function
Public Function GetUnloadOption(ByVal dummy As String) As Integer
'Unloads the image immediately after execution within NX
GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
End Function
Public Function ask_next_drf_entity(ByRef obj As NXOpen.Tag) As NXOpen.Tag
Dim part As NXOpen.Tag = Workpart.Tag
ufs.Obj.CycleObjsInPart(part, UFConstants.UF_drafting_entity_type, obj)
Return obj
End Function
End Module
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
' NX Font Update
Module NXJournal
Sub Main()
Next
End If
Next
Next
Next
Do
GoTo end1
End If
Continue Do
Else
End If
End1:
Do
GoTo end2
End If
Continue Do
Else
End If
End2:
End Sub
Return obj1
End Function
End Function
Return obj
End Function
End Module
RE: Need Help on below journal
Thnx,
Ryan
For starters, let's declare the fontIndex1 variable first thing in Sub Main (outside of any loops); this way you will only have to declare it once and you will be able to use it anywhere within sub Main. After moving the declaration to the position shown below, you will have to remove the other fontIndex1 declarations hanging around in your code (you won't need them and will get an error if you keep them).
CODE
Sub Main() Dim fontIndex1 As Integer fontIndex1 = workPart.Fonts.AddFont("ideas_iso")Now, any time you are changing the font used in the preferences, use the fontIndex1 variable instead of the hardcoded constant that the journal recorder gave you.
CODE
You can find some code to change the font in tabular notes here. I think it was written for NX 8.5, it will error on any version of NX that doesn't support true type fonts (NX 7.5? and below); but I think it can easily be made to work on NX 7.5 if needed.
www.nxjournaling.com
'Update All table cells
Dim myTabularNoteTags As New List(Of Tag)
If FindTabularNotes(myTabularNoteTags) = 0 Then
'no tabular notes to process
Return
End If
For Each tableNote As Tag In myTabularNoteTags
Dim numRows As Integer
ufs.Tabnot.AskNmRows(tableNote, numRows)
Dim numCols As Integer
ufs.Tabnot.AskNmColumns(tableNote, numCols)
Dim tableOrigin(2) As Double
Dim tableSectionTag As Tag
ufs.Tabnot.AskNthSection(tableNote, 0, tableSectionTag)
For i As Integer = 0 To numRows - 1
Dim rowTag As Tag
ufs.Tabnot.AskNthRow(tableNote, i, rowTag)
For j As Integer = 0 To numCols - 1
Dim colTag As Tag
ufs.Tabnot.AskNthColumn(tableNote, j, colTag)
Dim cellTag As Tag
ufs.Tabnot.AskCellAtRowCol(rowTag, colTag, cellTag)
'get the current cell preferences
ufs.Tabnot.AskCellPrefs(cellTag, cellPrefs1)
'change the font preference setting
'apply the new settings to the cell
ufs.Tabnot.SetCellPrefs(cellTag, cellPrefs1)
Next
Next
Next
Function FindTabularNotes(ByRef theTabNotes As List(Of Tag)) As Integer
Dim tmpTabNote As NXOpen.Tag = NXOpen.Tag.Null
Dim type As Integer
Do
ufs.Obj.CycleObjsInPart(workPart.Tag, UFConstants.UF_tabular_note_type, tmpTabNote)
If tmpTabNote = NXOpen.Tag.Null Then
Continue Do
End If
If tmpTabNote <> NXOpen.Tag.Null Then
ufs.Obj.AskTypeAndSubtype(tmpTabNote, type, subtype)
If subtype = UFConstants.UF_tabular_note_subtype Then
theTabNotes.Add(tmpTabNote)
End If
End If
Loop Until tmpTabNote = NXOpen.Tag.Null
Return theTabNotes.Count
End Function
CODE
You will still want to change the lines of code that set the font to use your fontIndex1 variable. Each part file has an internal font table to keep track of the fonts used in the part. So far, you have been lucky that the parts you have tested on have the desired font at position 51. This is not guaranteed to be the same for every file; to guarantee the proper font is used, use the value returned by the .AddFont method instead of a hard coded constant value.
The first 4 posts in thread561-375132: A new NX9 JOURNAL question might give a more thorough explanation, but don't use code from that thread as it is for NX 9 and will error if run on NX 7.5.
As per our default company standards we are using ideas_iso as "51" and they are maintaing the same in all the documents also, Any how its a valid and good point I will change that from font "51".
and one more question Section line label has been counted as a note when I am running the Journal is there a way to identify them individually and set different preferences... like this (I am unable to get the correct type of that label...
If note1.GetType().ToString() = "Section Line Label" Then
generalText1.Size = 0.2
End If
generalText1.Cfw.Font = fontIndex1
