UG NX 9 - Mold Wizard - EJECTOR PIN TABLE - USING A TEMPLATE
Hi Everyone, I am trying to use the Ejector Pin Table function in Mold Wizard - Mold Drawing. But I am not having any luck getting any output from this command. Is there a tutorial out there to show how to use this feature? My drop down for the Templates Name is blank. Where should the templates be stored?
What I really want is to label each pin individually ( able to be used in a text feature ) so it can be engraved on the retaining plate, then create a spreadsheet with those pin labels showing the stock and maximum cut-off length of the pins. Is this possible?
PKoc.
