Retrieve the component translations delta X,Y,Z values from the Component Properties Information
Hi Everyone, does anyone know if it is possible to retrieve the component translations delta X,Y,Z values from the Component Properties Information window?
I want to be able to reference the Z value to grow or shrink my component depending if the component is moved up or down.
I think it would be something very similar as to this thread: http://www.eng-tips.com/viewthread.cfm?qid=344785
I don't understanding the coding some people have posted and I don't understand yet how to apply it.
Any help would be appreciated.
Thanks.
Thanks.
RE: Retrieve the component translations delta X,Y,Z values from the Component Properties Information
www.nxjournaling.com
PKoc.
Add the associative measurement in the existing assembly, then add an interpart expression to drive the value into the component part file, make use of the expression value to change geometry as needed. I don't see why this would require "another assembly layer".
