Spreader Beam with Different Sections
I have to analyze some spreader beams that are adjustable by sliding HSS sections of different size into each other.
I have ASME B30.20-2013, but this doesn't deal with the design of spreader beams. I'm trying to determine what radius of gyration I should be using as the spreader beam is extended and half has an r of 1.2 while the other half has an r of 2.2.
Every spreader beam reference I can find deals with a single section. Does anyone know of a reference for different size sections being used together?
RE: Spreader Beam with Different Sections
you can get the allowable for a stepped column, but I'd just use the smaller section.
For inelastic buckling, it becomes a bit more difficult, but I suppose you could still use a numerical approach...don't know, haven't tried that.
That’s a tough problem to solve long hand. You have two different strength/stiffness, telescoping sections, with some play in their mating region which has the potential of exacerbating the buckling problem, if not handled properly. Newmark’s numerical integration methods provide one means of approaching a buckling problem where the compression member varies in stiffness over its length. Of course, FEA would be another approach. The fortunate thing is that the compressive stress/buckling problem can usually be accounted for with a slightly larger size (pipe dia.) for little added material cost. And, the material cost is usually not the major cost driver. This is usually true unless the lifting sling angle is to small. What do these spreader beams look like and how are they rigged from the beam up the main hook?
If you need to refine your answer, I 2nd BA's suggestion for "Theory of Elastic Stability". As he says, they have this exact problem in the book. I've used it successfully in the past to check adjustable pipe braces. If you set up your solution in a spreadsheet you can easily check for multiple combinations of lengths and stiffness.
1) Fire up your favorite FEM program.
2) Model the the spreader as two moment connected columns with a conservative kink at the joint.
3) Split the two tubes up into four or so members each .
4) Modify your stiffnesses according to DAM and run a non-linear P-delta analysis.
I took AISC's night school course on stability recently. Apparently, DAM is becomeing quite ubiquitous for rigging applications.
rb - this is for existing spreader beams that a rigger has on site and is trying to get reliable calculations and capacities for. He has some random capacities from about 20 years ago, but the markings have become unclear.
AUCE98 - I will look into that reference right away. That may be just what I need.
dhengr - You're exactly correct that they're telescoping. They are square HSS sections one side a full inch larger than the mating side with a thicker wall. I could be conservative and use the smaller section only, but I don't want the rigger to look at me cross eyed because he's already lifted more weight multiple times with these beams. The weight is slung directly below the lifting hooks, so the only bending is the self-weight with the play where they mate and the P-delta from the high compression force.
kootk - I think that would be a good solution, but could be time consuming having to do 10 models for each spreader beam to capture each length that each one can achieve with the telescoping.
http://www.eng-tips.com/viewthread.cfm?qid=278129
with 1/2" thk steel sections, I'd be worried about the load transfer from one to the other.
I've got a crummy graph from a text ... gives allowable in terms of the smaller section.
if I1/I2 = 0.5 and a = 0.5*L, then m = 0.6, and Pcr = pi^2*E*I1/L^2/0.6
We don’t know any of your loads (load ranges), member sizes, thicknesses, beam lengths, end fittings and details, etc. When your licence is on the line, and you should design to some reasonable set of standards, you should be very careful leaning to heavily on a statement like ‘the rigger has already lifted heavier loads with these spreader beams.’ The way some of those guys work, if it hasn’t started to fail during this lift, it still has much to much factor of safety built into it, so they can lift a heavier load with it the next time. Many of them are very good at what they do, and I’ve worked with a number of them, but riggers pay high insurance premiums to cover their type of work, and many/some of them are kinda cowboys about the chances they will take, or the way they will eat into margins of safety. I would check the telescoping mechanism and its locking/pinning means to minimize any play in that part of the system. Finally, inspect the entire beam for wear, nicks, cracks and the like. I believe that ASME BTH-1 requires that these beams be load tested to 1.25 or 1.5 times their load rating, before actual use.
The beams are typically small (4" - 8") square HSS or round pipe with thicknesses around 3/8".
all - Thank you for your input. I ended up setting up a spreadsheet using the approach in Theory of Elastic Stability and accounted for P-delta by determining the maximum "kink" that can occur in the beam when fully extended.
BA
my point was if they said "90k on it ? are you crazy!?" then you know that it's not rated at 60k.
and of course it can have different rated capacities for different extensions.
