Using variables in a message box function with VBA
I have an Excel document that I am adding VBA code for and I need to display the values of two variables in the message box so the user can see what the remaining stock values are for a certain product when they place an order.  I entered the commands in just as my reference book says but the message box doesnt show the value of the variables.  Does anybody know how to make this work.  I have the code pasted below.  Thanks a million.
Sub Insert_Order()
' Insert_Order Macro
Dim Item As String
Dim Ordered As Integer
Dim Instock As Integer
Dim Remaining As Integer
Item = Worksheets("Order Form").Range("C6").Value
Ordered = Worksheets("Order Form").Range("C8").Value
Instock = Application.WorksheetFunction.VLookup(Range("C5"), Range("Inventory"), 6, F)
Remaining = Instock - Ordered
If Remaining >= 0 Then
    Sheets("Submitted Orders").Select
    Rows("3:3").Select
    Selection.Insert Shift:=xlDown
    Sheets("Order Form").Select
    Range("C4:C11").Select
    Selection.Copy
    Range("A3").Select
    Selection.PasteSpecial Paste:=xlPasteValues, Operation:=xlNone, SkipBlanks _
        :=False, Transpose:=True
    Range("C14:C19").Select
    Application.CutCopyMode = False
    Selection.Copy
    Range("I3").Select
    Range("A1").Select
    Range("C4").Select
    Selection.ClearContents
    Range("C5").Select
    Range("C8").Select
    Range("C4").Select
    MsgBox "You have Remaining Item remaining in stock.", vbInformation, "Order Entered"
Else
    MsgBox "There are only Instock Item in stock.", vbCritical, "Order Rejected"
End If
End Sub
RE: Using variables in a message box function with VBA
Hi
That's easy:
use the &-operator (+ also works with strings)
example:
MsgBox "text" & numbervariable & "more text"
Kim
Try this:
MsgBox "You have " & Remaining & " Item remaining in stock.", vbInformation, "Order Entered"
It is not considered good practice to use the + operator with strings as VB will first try to process your strings as numbers, which can lead to confusion.
msgbox "1" + "2" ' yields 3
msgbox "1" & "2" ' yields 12
Oh I see. It works now. Thanks for the help everybody. I really appreciate it.
