Custom Functions in NX
Can I create a custom function in NX? Maybe a function isn't the proper method but I want to apply the following calculation to multiple sketch dimensions with unique inputs.
function(n)
Input:
n - desired length
Output:
constant*round(n/constant)
Scott
RE: Custom Functions in NX
I do not know if I understand your question, but Have you tried using expressions? ponder
with this command you can set up operations and use Boolean for comparison
You can see this command with Ctrl + E
You can use expreesiones to sketch, wipes, patterns and more.
Yes I've used expressions. Assume "constant" is an expression. In my sketch, I have to type the follow formula...
Constant*round (12.6/Constant)
12.6 is just a number I made up but it will always be different. I want to create a formula so I can just type. ..
MyFunction (12.6)
It's like a reusable expression or formula
Kenevil --
One of the examples I posted in your other thread related to this topic is actually a rounding example similar to this. Take a close look rounding_examples.dfa inside the zip file. smile
Taylor Anderson
NX Product Manager, Knowledge Reuse and NX Design
Product Engineering Software
Siemens Product Lifecycle Management Software Inc.
(Phoenix, Arizona)
