pile load test
pile load test
Good day
we are currently preparing a pile load test.the head of the pile is a little bit broken as per the attachement.
1- is it ok or it must be repaired ?
2- how much the pile should be extended above the exacavated soil level ?
RE: pile load test
Projecting part of pile can be more than shown, if needed.
RE: pile load test
RE: pile load test
An 500mm excavation around the pile may be required to get a space to place the dial gauges.
