amada fo315 nitrogen cutting nib on hole
I get a tiny ball or bump when cutting with nitrogen. No matter the thickness of material or hole size. Its the start/stop point. I've tried different nozzle types, focus heights & speeds. I get a clean cut everywhere else. I'm currently cutting 16ga crs with N2 because of the amount of small holes that I have to produce. Also in standard or high speed set ups. Gas dwell is .5 Any input would be much appreciated.
"I am stuck on Band-Aid brand, 'cause they are stuck on me"
RE: amada fo315 nitrogen cutting nib on hole
I have this issue also
Even if I over cut my lead....
