XY Coordinates from a Polyline
thread555-195727: XY coordinates from a polyline
I'm new to this forum, however I found this thread from 2007 to be very helpful for what I am trying to do.
I would like to extract the XY Coordinates from a 2D Polyline, but with more extracted data points along the curve.
The ptexport.lisp did exactly what I need it to do but does anyone know how to change the lisp code to have more (10x more) XY data extraction points?
It's been a while since this thread has been closed but I thought I'd give it a shot.
Any help would be greatly appreciated! I'm fairly new to the lisp coding/command.
Thank you!
-Scott
RE: XY Coordinates from a Polyline
I would set as many points as you want on the polyline with _divide and then put them into a *.csv file with _dataextraction.
Hello Occupant,
Thanks for the help!
After I posted this question I realized I could do exactly what you suggested and it worked perfectly.
Thanks for replying with the help.
Cheers!
