Friction Isolator
Friction Isolator
Hallo ,
I´m having an issue with Friction Isolator. I´ve defined a SDOF-System (look attachment). There is a single mass in x-Direction (200). I´ve defined a stiffness in U1 and U2 direction (nonlinear).
Now I want to change the Friction coefficient (slow and fast) to calculate the displacements of the mass-point. But it does not matter what i choose for the value , the displacement is always the same!
For the Load case I´ve defined a time history function and a ramp-function (this is for the vertical Load of the friction Isolator).
I hope someone can help me.
RE: Friction Isolator
Load case(s) needs to be specified as Nonlinear.
thanks for your advice! I´ve forgotten to define weight. This is how it works.
