Built up wood beam bearing on wood post of narrower dimension
The width of an existing built-up 4-ply beam of 2x12's is 6". It bears on a 5.5" square wood post. The beam has been built so that one face is flush with the face of the post below, but the other face of the beam is 1/2" beyond the post below.
Is that ok, or should a 2x6 be wedged tight to the beam soffit and fastened to the side of the post, so that the beam is bearing for its full 6" width?
RE: Built up wood beam bearing on wood post of narrower dimension
