Simple API for View Options
Does anyone have a simple API script for turning on Node IDs (only Nodes) that they'd be willing to share? Complete novice to API, and having some trouble with the syntax. That would be a huge help. Many thanks
RE: Simple API for View Options
Sub Main
' Connect to the current running FEMAP as App
Dim App As femap.model
Set App = feFemap()
' Create a new empty feView Object
Dim feView As femap.View
' Connect it to App
Set feView = App.feView
' Integer to hold the current view ID
Dim viewID As Long
' Find out what the current active view ID is
rc = App.feAppGetActiveView( viewID )
' Use the viewID and load the feView object with that
' view's settings
If feView.Get( viewID ) = femap.FE_OK Then
' Make sure nodes are being drawn, FVI_NODE is
' defined as "7" which is always nodes
feView.Draw( FVI_NODE) = True
' And turn on the labels
feView.Label( FVI_NODE) = 1
' take this API's feView object and update
' the one in the FEMAP database
rc = feView.Put( viewID )
' Force a regen so that this view gets redrawn
rc = App.feViewRegenerate( viewID )
End If
End Sub
www.stressebook.com
Stressing Stresslessly!
Is there a repository of API programs you built I can get access to other than Custom Tools? That would be awesome. Please email me at stressebookllc at gmail dot com.
One of the tools I am looking for is to move a nodal load from one node to another.
www.stressebook.com
