Shear on simply supported beam
Guys, I am having another engineering discussion with my coworker. Let's say you have a concrete beam simply supported 10 ft long. You have 10 kips factored point load that can be anywhere on the beam. The beam has 12" d distance. What Shear load would you design the beam for? Let's neglect the dead load from the beam.
RE: Shear on simply supported beam
(neglecting semantics like AASHTO where you'd need to offset your critical section by dv instead of d, etc.)
why not be conservative at use 10 kip ? the difference seems small ...
- >9 kip for loads closer to the support. At that point it would become either STM or a combination of shear friction and direct bearing rather than diagonal tension.
That's the theoretical answer that I believe we're debating. In practice, just 10 kip of course.
A more interesting question is what is the maximum concentrated load which could be placed between the support and distance 'd' from the support?
BA
For the original question, I would use 10 kips. Life's too short to go into any more detail than that...
