how to understand the gun-fire vibration spectrum
why at the same frequency, there are two different G^2/Hz?
what is the G^2/Hz between two adjacent Hz numbers?
thanks.
Frequency (Hz) PSD
(G2/Hz)
14.949 1.00E-07
14.949 0.002403
18.333 0.007607
21.718 0.002403
21.718 1.00E-07
31.881 1.00E-07
31.881 0.002403
36.667 0.007607
41.453 0.002403
41.453 0.002922
49.138 0.003356
49.138 0.004555
55.000 0.008511
60.862 0.004255
60.862 0.003295
66.565 0.004297
66.565 0.004991
73.333 0.009763
80.102 0.004381
80.102 0.004996
300.000 0.01464
600.000 0.04347
700.000 0.04347
2000.000 0.002246
thanks.
Frequency (Hz) PSD
(G2/Hz)
14.949 1.00E-07
14.949 0.002403
18.333 0.007607
21.718 0.002403
21.718 1.00E-07
31.881 1.00E-07
31.881 0.002403
36.667 0.007607
41.453 0.002403
41.453 0.002922
49.138 0.003356
49.138 0.004555
55.000 0.008511
60.862 0.004255
60.862 0.003295
66.565 0.004297
66.565 0.004991
73.333 0.009763
80.102 0.004381
80.102 0.004996
300.000 0.01464
600.000 0.04347
700.000 0.04347
2000.000 0.002246
RE: how to understand the gun-fire vibration spectrum
I'm more curious about the "1e-7" values ?? do these frequencies match up with isolators ??
Your semilog plot will show 4 little "houses" starting at 18.333 Hz, which represent the fundamental and its next 3 harmonics. They have a non-zero width, possibly because the customer wants to account for variations in the frequencies from the gunfire. However, by putting wide envelope around these frequencies, they may have added a substantial amount of energy that might not be present in the real scenario. You should ask your customer for the the raw data and graph them together. If the spectral lines in the raw data exceed the tops of the houses, then they did a reasonable job converting the energies. Likewise if the spectral lines are actually distributions.
TTFN
[IMG http://tinyurl.com/7ofakss]
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
