Invisible Expression not editable in NX8.5
I have a visible dimension but I have the following message when trying to modify in the sketch or details or expression menu
Part cleanup give nothing
TIA
TIA
Didier Psaltopoulos
http://www.psi-cad.com
RE: Invisible Expression not editable in NX8.5
I found a WA
1°) Delete dimension
2°) Par Cleanup / Remove unused expression
3°) Create new dimension
Didier Psaltopoulos
GTAC gave me another solution by using Edit Feature Playback
Didier Psaltopoulos
