E Young's Modulus of Intact Rock and its unit.
I calculated the young's Modulus of an intact Rock by UCS. Stress/Strain at max.
so what is it's proper unit when stress is kg/cm2 and strain in mm
and is it right if I put L length is cm and deflection in mm ( Delta L mm / Li cm) or its unit must be the same? ( both are mm) ?
RE: E Young's Modulus of Intact Rock and its unit.
TTFN
[IMG http://tinyurl.com/7ofakss]
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
f-d
ípapß gordo ainÆt no madre flaca!
Anyway, you can check your value with tables, if it is a hard intact rock, young's modulus value should likely be in the order of a few GigaPascals up 20 GPa depending on rock type.
1 GPa = 10000 kg/cm2 = about 10000 tsf
www.mccoy.it
