calculation of hydro static test pressure for pipeline of API 5L grade B of 600mm dia
i am working with client on a project of pipeline for water 20 km long. our design engineer designed the pipeline according to API 5L grade b 600 mm pipe using carbon steel of minimum yield strength of 30000 psi. i m confused as design engineer has approved 218 psi as hydro static test however my point of view is that it should be tested at 600 psi so i need help in this as what should be the test pressure
RE: calculation of hydro static test pressure for pipeline of API 5L grade B of 600mm dia
You need to know or tell us the design pressure or MOP, design code, highest point versus lowest point, pipe wall thickness etc to calculate the minimum and maximum test pressure.
Providing that you don't exceed the rating of connected equipment or exceed the yield strength of the pipe at the lowest point you can test to a higher pressure if you want, but most people just aim for the minimum base don design pressure / MOP.
BTW, Grade B is normally SMYS of 35,000 psi
our pipe line carries water pumped by turbine pumps ,standards adopted are AWWA standards, thickness of pipe wall is 6.4 mm dia of pipe is 600mm, our specification shows test pressure as 1.5 times the maximum working pressure know problem is in my opinion maximum working pressure can only be calculated from yield strength,dia,and thickness of wall which comes out 600 psi
there is no any other fitting is connected to pipe
pipes are welded adopting but joint with four laps according to API 1104 standards
I don't know what design factor AWWA use, but yes, pipe of this size, wt and grade is good for approx. 35barg design pressure.
just ask the designer for his calcualtions and where he gets his design pressure / MOP from and see if you agree.
my opinion is that pipe of 24 Dia, 6.4 mm wall thickness, of steel with SMYS of 30000 psi should have working pressure of 26 bars and should be tested on 39 bars
Depending on your design calculation and design factor then yes, your pipe can take 26 barg or higher as an MOP and therefore if you test it to that pressure x 1.5, then you could uprate your system in the future without necessarily doing another test.
I don't know which of you has the contract power to force the other do one thing rather than another, but you probably need to find the AWWA design code and point out that the calculated test pressure is the minimum. If you are the client then you can insist on higher pressure providing all parts of the system can cope and you don't have a large elevation difference along your pipe. Minimum test pressure should apply a the highest point - make sure whatever test pressure you choose doesn't exceed yield strength and the lowest point.
