Derive dimensions and tolerances from Proe model or drawing
Hello all,
I am working on an automation project in which i need to get the Proe model dimensions and tolerances in excel sheet (this may not be linked) is there a way to get this. Thanks.
Sundeep Panchal
Proe-Creo 5.0
RE: Derive dimensions and tolerances from Proe model or drawing
Look at the Model Info output. It will be near Feature Info in the menus or icons.
Thank you, it was hard to find but i got it :
Its under- Info-> Model-> Under Feature List (click the cube)
PTC changes the location and I don't have copies of all versions, so it's hard to tell where to look. Glad you found it.
