Pad flange calculation base on ASME code UG-37
RE: Pad flange calculation base on ASME code UG-37
ChiangJaron, see your sketch and UG-37. No area contributed by nozzle neck, A2 = 0. Area contributed by reinforcing element of te and OD, ID, etc. for A5. A1 & A4 per UG-37.
Doesn't appear to me that PVE will exactly model this connection, but it should be possible to perform the calculation per above.
Mike
