nx environment sketches list order
Hi
Can someone help in this
when I reorder the sketches in the part navigator
the order in the environment sketches list do not change.
Thanks in advanced
Thanks in advanced
RE: nx environment sketches list order
May be because of time stamp order.Please deactivate the dependent features if any and then try it out.
Mathi K
I clear my question
with timestemp checked I create a sketch and draw one circle
I exit sketch task environment and create another sketch
and draw a rectangle with no constraint and exit sketch task environment
now in part navigator i have 2 sketches in this order
sketch0000
sketch0001
this also seen in the same order in sketch task environment
now I drag sketch0000 to be below sketch0001 so in part navigator I have
this order
sketch0001
sketch0000
but in sketch task environment the order is still
in this order
sketch0000
sketch0001
and I expect that the order to be the same as part navigator
Thanks in advanced
I don't see the behavior you describe in either NX 8.5.3.3 or NX 9.0.3.4
www.nxjournaling.com
I mean in the drop down list window next to task enviroment flag
theire the list of sketches refuse to change when I change
the order in the part navigator the drop down window list is the same.
Thank you very much for your interest in helping
Jerry J.
Milwaukee Electric Tool
http://www.milwaukeetool.com/
If the secobd sketch dependent on the first sketch
Nx Not let you reorder them in the part navigator
thanks
