Casting a Composite material characterization
Hi Guys,
I currently investigating a casting procedure that the company i have been working for has had a lot of issues with. So I outfitted this with pressure transducers and load cells. I applied to load cells on the top and bottom of the cast, and pressure transducers on the OD of the cast. So essentially the finished product looks like a cylinder. The odd thing is though that I am getting a higher pressure reading on the radial transducer that the surface pressure. Is this possible? I understand each material has its own Poissons ratio, however can this happen?
--MechengineerNT
RE: Casting a Composite material characterization
Sorry, bad grammar. I've been getting higher pressure readings on the OD of the part as compared to the surface of the part. We are applying a pressure only to the top surface.
We here can't see your part, so it's hard for us to understand how the OD of a cylinder is distinct from its surface.
Could you perhaps attach a photo or drawing?
Mike Halloran
Pembroke Pines, FL, USA
