Commands in ANSYS explicit STR to model the Perzyna material model?
I want to use the Perzyna model in Explicit/STR in order to model strain rate effects.
I have the Perzyna material constants for my material, and since the Perzyna material model is not included in the workbnch materials, I guessed that the only option to include it in the analysis is manually inserting the material data via a command in ANSYS WB. I found out that it is not possible to use commands in Explicit/STR, so I gave up...
What option do I have to use the Perzyna model in Explicit/STR?
Tanks.
