Localize soften BeCu
I have a small BeCu Alloy 17200 1/2HT temper stamping that requires softening over a .100" long section without affecting the material properties .100 away from this area.
I'm looking to develop equipment to do this for high volume manufacture. Around a 400/min rate would be fine. Can anyone recommend a supplier? Likely a laser application.
RE: Localize soften BeCu
http://www.visotekinc.com
Uconnmaterials
Are you sure that you can accurately feed and locate these at 7/sec?
