Code or non code question.
I am looking for guidance on an enclosure used to house electronic equipment. The enclosure is a rectangular flanged box with o-ring seals and flat lid. The enclosure will be used to keep the equipment dry while submerged in water to a depth of 60-70 feet. When would this become an unfired pressure vessel and require ASME construction.
RE: Code or non code question.
Code methods could be used in design if one wished, although there might be better ways.
Mike
*However*, I would use the design rules of ASME Sect VIII Div-1. They are fairly 'readable' and easy to work to.
