Inventor multi body parts
When i have made a metric ipt using multi body parts, then going to Manage tab and make components, selecting components and selecting metric assembly, once the assembly is created if i inspect a part it is metric but if i open that part from the assembly and inspect measure the units are now imperial. Any ideas its driving me nuts.Im using inventor 2015
Thanks for any help.
RE: Inventor multi body parts
Or...
You can change each template in the Make Components box to be a Metric IPT instead of a Standard template selection.
