Excel (2010) table comparison and list generation
Hi folks,
I'm wondering whether someone with a vastly better knowledge of Excel 2010 than me would be able to help me?
I have a table of parts (washers) of varying dimensions and I'm trying to find groups of parts that have sets of dimensions that are equal or smaller in every dimension (see the .xlsx spreadsheet attached) and generate lists of those parts. What I'd like to make Excel do is to take the header of each list, i.e. the part name, search for it in the first column of the table then, when found, compare each of its dimensions to the same dimension in each of the other parts, building up a list of part names that are smaller in every dimension than the subject part. If any part is larger in any dimension that part is disregarded.
I've been playing with VLOOKUP (to search for the part), IF and AND functions but not managed to successfully do what I need.
Would someone be able to give me formula that will do the comparison and build the lists?
Many thanks in advance!
Dave
Dave
RE: Excel (2010) table comparison and list generation
CODE -->
Sub washer() Dim iRow1 As Integer, iRow2 As Integer, i As Integer, j As Integer, hits As Integer Dim source(8) iRow1 = 2 iRow2 = 2 Do Until IsEmpty(Cells(iRow1, 1)) For i = 0 To 8 source(i) = Cells(iRow1, i + 1) Next i Cells(23, iRow1 - 1) = source(0) hits = 1 Do Until IsEmpty(Cells(iRow2, 1)) If iRow1 <> iRow2 Then test = 0 For j = 1 To 8 If Cells(iRow2, j + 1) <= source(j) Then test = test + 1 Next j If test = 8 Then Cells(23 + hits, iRow1 - 1) = Cells(iRow2, 1) hits = hits + 1 End If End If iRow2 = iRow2 + 1 Loop iRow2 = 2 iRow1 = iRow1 + 1 Loop End SubRE: Excel (2010) table comparison and list generation
