UNS S41425 - NACE - FORONI SPA
Hi All,
I would like to check what is the heating treatment of the following material - UNS S41425 under NACE compliant?
I can find non-nace heating treatment for UNS S41425, but not the NACE version in MRS0175.
I was told it was implemented by Foroni SPA, but I can't seen to find the document.
Please advise.
Jeffrey
Please advise.
Jeffrey
RE: UNS S41425 - NACE - FORONI SPA
Wrought low-carbon UNS S41425 martensitic stainless steel in the austenitized, quenched, and tempered condition shall have a maximum hardness of 28 HRC.
You are right. But I am looking for the heat treatment procedures.
For S41427, the heating procedure is written in NACE but not for S41425. Thanks.
Nace has set the hardness to be at 28 hrc. But astm stated 32hrc instead. Therefore, i believe there must be guidelines to the heat treatment method.
You are right. I initially used the heating guideline from ASTSM A 473. However, as I need to compliant to the NACE hardness (29 HRC), I am searching for the heating procedure.
As you mentioned, instead of 1100 deg F, I should increase the temperature to 1250 deg F.
May I ask where can I achieve or obtain the document from?
Thanks for your help and many apologies for the late reply.
Jeffrey
The 1250 deg F was based on a quick review of a technical paper on heat treatment and secondary hardening characteristics for similar grades of supermartensitic stainless steel. I would use the 1250 deg F as a guide and adjust or fine tune the actual tempering temperature.
