UG-16 (C) CAPS - ASME VIII Div.1
does UG-16(c) mill undertolerance apply also to fittings and caps? I've founded in some drawings caps with 12,5% indication but also some other calculation report where this undertolerance is set to zero. Could anyone help me? Thank you!
RE: UG-16 (C) CAPS - ASME VIII Div.1
If I used fittings which are not in accordance with B.16.9 in a vessel designed with ASME, would this tolerance be valid?
