Switch input mode with jumper
Could anyone suggest switch/input selector for mounting on PCB (through-hole)? Device have two inputs, Mic and Lin-in input. Capsule Micro Electret Mic Ø10mm in mounted on PCB, Mic is default input mode. When I need switch to Line-in input, I just put jumper. Or maybe some other small handy switch.
RE: Switch input mode with jumper
Only thousands of PC mount switches out there..
www.digikey.com and start searching for the exact size/rating/button type,etc.. that you need
An internal jumper?
Just use the 0.1-inch spacing header pins and the sort of block-jumper as so often seen in PCs.
Don't they make 1/8" plug sockets with switches, so that plugging in the line input could switch off the mic?
Mike Halloran
Pembroke Pines, FL, USA
Yes, internal jumper, or DIP switch. DIP switch perhaps better, I need SPDT DIP Switch (ON-ON, without center position). Searched on Digikey, but still didn't find good accurate one. The line-in input is Terminal block, not 1/8" plug socket, and Mic is on board.
Accurate? Switch? What "accuracy" spec are you imposing on the switch?
TTFN
[IMG http://tinyurl.com/7ofakss]
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
Hint: You get better suggestions, sooner, and waste less of our time and yours, when you bound the problem space as completely as possible with your initial question.
Mike Halloran
well, I mean internal switch on PCB (J4)
Mainly, just low profile and reliable, low PCB space.
