Exploded Views in NX 9
In NX 7.5, this was a little convoluted, but it worked. I would create the explosion, adding the guide lines, in the model side of the drawing file. But to get it to show up on the drawing I would go to View -> operation -> save as, and save the view of the explosion, then I could select this when placing a view.
I have tried this process in NX 9, but the newly saved view is not showing up as an option when placing the view, even though it shows up when I return to the view save as operation.
So how do I get the exploded view to show up in the drawing?
Thanks in advance for your help.
RE: Exploded Views in NX 9
When you add the view, make sure the "selected part" is the drawing file and not the model file.
www.nxjournaling.com
That fixed the problem. Thanks!
