DNV Pad Eye Contact stress Calculation explanation
Hello all,
I am looking at the DNV's Design of Padeye (Appendix D) and came across a formula for contact stress (Figure D-1 Padeye) and was wondering if someone could explain the formula to me please.
The formula states that:
Contact Stress = 23.7 x (SQRT(RSL/DH x t))
RSL being Resultant Sling Load
DH being Bolt hole diameter
t being thickness
and 23.7 is a constant
What I am getting confused about is the SQRT. Using this formula in MathCad the end units are not MPa but end up being kg^0.5 / m^0.5 x s
Have I missed something obvious.
Many Thanks
RE: DNV Pad Eye Contact stress Calculation explanation
I believe this is a very simplified hertzian contact calculation. The 23.7 constant isn't just a constant, it is the product the safety factor of a couple of other things which have units and shouldn't vary as long as you are doing the calculation for steel, and you can give it units of MPa^1/2 to output the correct units in your calculation.
Many thanks for the replies people :)
calculator looks awesome!
