export iges or step
export iges or step
there's a trick to export automatically a step or iges from an assembly , for every single name part?
Yes i know there's an external tool (fantastic for main part), but when i need to export the screws or ejectors ecc.. whith the external tool, obviously it export a single part with own WCS.
Now i have to select manually all solid of the same standard part in NX and export give it the correct part name... and usually i have more then 100 component screws pins ejectors...
NX 7.5 64bit
NX 9.0.3.4 MP4 64bit
www.studiotreccani.com
RE: export iges or step
Jerry J.
Milwaukee Electric Tool
http://www.milwaukeetool.com/
NX 7.5 64bit
I don't remember if IGES works the same way or not...
they don't use a program that recognizes the assembly structure,
they have a unique file for all the assembly.
then they import the single step of any single part and change the layer or assign to a group or i don't know...
NX 7.5 64bit
