Splitting of Digital signals-i need 2 outputs from 1 input
Hi All
I'm a new member on this forum and really hope to get some tips and of course share my knowledge and experience.
I just want to know how can i split digital signal to terminate in two different locations.(i need two outputs from 1 digital input).
Many thanks for your advice
RE: Splitting of Digital signals-i need 2 outputs from 1 input
Mike Halloran
Pembroke Pines, FL, USA
As long as you don't need isolation, just use buffers made for the digital family that produced the original signal; TTL for TTL, CMOS for CMOS and, yes, a relay for contact closure.
Then, there are optoisolators, transformers, isolation amplifiers... How can we know what signal type you are dealing with? If frequency is high, you need to think about rise-time, reflection and ground bounce. If FCC is involved, you need to worry about EMI/EMC issues.
Mike is right - there's no answer to your question. You have to ask a more specific one. And once you do so, you will read the answer from your question.
Gunnar Englund
www.gke.org
